跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
Why my laptop stopped working?
My acer laptop stopped working.After working on it for sometime it was shutdown and after one hour i powered it up but the screen was blank though the power button was glowing and the battery indicator was also glowing and the rest of indicators were not glowing but i can hear sound seems like hard drive spin. please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
my acer chromebook was working fine last night in the morning i found out it was charging overnight it stopped working it won't turn on please help!!!.
完成的
My Acer laptop suddenly getting off. I don't know why. Again I try to power on but it's not getting on. The indicators also not glowing. Please help me to solve the problem.
完成的
添加一条评论
5个答案
已选择的解决方案
this problem may have been solved but just to add..try taking battery and charger out, hold the power button for up to 1 minute then tap it off and on for a further minute. Allow the laptop to sit without battery or AC power for 20 minutes and then boot up. Apparently this gets rid of any static build up that is preventing boot. It's on quite a few web sites...works for some, didn't work for me!
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Check with an external monitor and see if it shows you anything.
这个答案有帮助吗?
得分 2
添加一条评论
you need to do a bios flush. It is simple, google acer aspire one bios flush and you will get ur answer. Download files on a empty mem stick and folow the procedure. I did mine a couple of times
Update
download new bios from http://sites.google.com/site/maclesblogs...
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn’t boot anymore. It’s only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
这个答案有帮助吗?
得分 0
添加一条评论
helo my laptop is just on and after that it get the totally blank
这个答案有帮助吗?
得分 0
5条评论:
helo sir my laptop is when i was swtced on after that it get the blank sheet
完成的
What model laptop is it and what have you tried so far to fix it?
完成的
my laptop model acer Nplify 802.11/gin
my laptop is not working when i was switch on system it get the blank
完成的
what have you tried to fix it?
完成的
Hi if i switch on my acer it just said acer explore beyond limits and then nothing happend futher why is that.Please help
完成的
添加一条评论
My acer aspire is not starting . Earlier whenever I use to get this problem I had to remove the charger press the power button and when it starts blinking I put the charger and it starts .today nothing is working.please help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ramesh 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 19
总计 24,659
