跳转到主内容
加入维修社区 - 创建账户
第三代索尼 PlayStation 5 DualSense 手柄的维修指南、拆解及故障排除信息。通过型号 CFI-ZCT1W 和主板型号 BDM-030 识别。
Adaptive Trigger Auto Trigger
I was just finished installing the Hall effect on the controller, and they work fine. However, the trigger motor for adaptive triggers on R2 activates on its own. I disconnected the flex cable, but it still triggers. It doesn't seem to be the springs or anything as the triggers work and they retract, just that the triggers just activate to like a resisting gun trigger every 4-ish seconds. Its seems to be software-related. An y Fixes other than disconnecting the wires?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Hi!
What does gamepad tester says? Also that it's pressed in? Is the firmware up to date? How are the traces? Are none of them are damaged during soldering?
Thanks!
由完成的
The traces are fine now the auto clicking stopped but when I use the https://ds.daidr.me/ Dualsense Tester the Triggers only go into resistance. The auto trigger mode does the same thing as resistance. The Only trace that was accidently torn isnt even related to that. Im fine without the adaptive triggers but my mute button doesnt work
由完成的
gamepad tester says normal, btw
Its not pressing in on its own, its just the adaptive triggers. Firmware is latest
由完成的
Hmm, can you share some pictures with us regarding the motherboard and it's traces? Then we can take a look at it! Hopefully that is OK :)!
Thanks!
由完成的
添加一条评论
1个答案
Check button for firmware reset.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elvin Eve 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 37
总计 274
