跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
Battery connection pods on board
I have accidentally removed the pod on the pcb board of the iPod. It's the one in the middle. Does someone have a diagram of what each of those pods do and a possible fix? Thank you! Ps- I still have the removed pod. Any ideas?
*bump*
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Chris, I assume you are talking about the solder pads?
完成的
添加一条评论
2个答案
已选择的解决方案
chris, if you are talking about the solder pads, take a look at the attached image. It is from a 3rd gen but should still be the same. If your pad came of the board, it can be tricky to repair it again. Take a look at this video. Decent tutorial and it might help you to see what you are up against. If you have difficulty soldering etc, then you could try something like this epoxy.
这个答案有帮助吗?
得分 2
1条评论:
While the information provided is good the solder points are different on the 3rd gen.
完成的
添加一条评论
Posted about this outside.
http://www.techjamaica.com/forums/showth...
That is for the A1367 4th Gen iPod Touch. Hope it helps.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 2,657
