跳转到主内容
加入维修社区 - 创建账户
任天堂 Switch 游戏主机的一款更实惠、纯掌机版本,具有集成式 Joy-Con 控制器和稍小的屏幕。于 2019 年 9 月 20 日发布。
Volume up button doesn't work.
I got a new cat recently who required some training, and unfortunately, I think she urinated on my switch. The only issue I've noticed since cleaning it is that the volume up button no longer works. The volume down button works, the power button works, everything else seems fine, I just can't turn the volume up, and there's no setting in the Switch itself to adjust volume either. I have not yet tried anything to fix it because I'm quite inexperienced working on electronics myself, but if there is a way to fix it myself, I'll certainly try. The button does not appear to be stuck; it presses down and up normally, but it just doesn't do anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi there!
Yes, those buttons are replaceable!
Your in luck I guess :)!
You can follow this guide: 任天堂Switch Lite 屏幕更换 (from step 41 all the way till step 43).
So you dont need to remove the motherboard or other components!
If you have any questions, please let us know!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kai Hayden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 199
