跳转到主内容
加入维修社区 - 创建账户
Sony Cyber-shot DSC-W5 5.1 百万像素
Can't open battery compartment
I haven't used my Sony dsc-w5 for several years. I am now unable to open the battery comparment. I suspect the battery has leaked and corroded the latch from the inside. How can I open the latch without damaging it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
charles, you could try and soak the corner with the battery door in a backing powder solution, and/or use a sprayer to try and spray some around the corners. Also, a toothbrush scrubbing might get it loosened. If you soak it, just place that particular corner in a solution, not the whole camera. The only other way is to disassemble the camera, the attached images may help you with that task. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
charles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,123
