跳转到主内容
加入维修社区 - 创建账户
Logitech G300S 光学游戏鼠标(2015 年发布)的维修指南、拆解信息及故障排除。
How do I open it without breaking it?
Title says it all- I'd like to inspect the inside to see why middle click sometimes does not work. I had an older one 5+ years ago that I replaced after the right click began double-clicking too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It's usually the microswitches. You'll need to order a set of Omron switches like this: https://www.ebay.com/sch/i.html?_nkw=omr... -- mouse type really doesn't matter as they're all wired the same, but look for ones made for Logitech mice. You might need to order ~10 when you only need three, as most sellers insist on selling you 10 at a time in the US, so bear that in mind. It's usually best to do all 3 at once, since one failing tends to mean the others are next.
As far as opening it, look under the stickers on the top and bottom - that's Logitech's favorite hiding spot. Most of the time, I consider mice eWaste when they break, but gaming mice tend to be expensive enough that it makes sense to repair them if the parts are available and you can do it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tyiscringe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 422
