跳转到主内容
加入维修社区 - 创建账户
Nikon D3X 是一款由尼康公司于 2008 年 12 月发布的 2440 万像素专业级全画幅数码单反相机 (DSLR)。
Clock battery on D3x
I recently bought a second hand D3x, Im very happy with it. I read somewhere (?) that I may need to replace my clock battery. This makes sense to me as every time I take the battery out to recharge, it resets to 2007 and resets the counter. Where is the clock battery on this camera and is it something I can replace myself?
If I recall correctly they gave a battery type in the article, which I sensibly didn't write down.
I trust you can assist me with my current quest. Thank you in advance for being here in the first place.
Bebb
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Is this what you are looking for? Replacing D3 Camera Clock battery
这个答案有帮助吗?
得分 1
1条评论:
The clock battery is located in the roof of the main camera battery compartment, concealed by a slide out cover. Its easy to locate and the battery in question you require is a CR1616 - 3 volt battery which are readily available.
I find they last a long time having only replaced them very occasionally on both the D3 and D3X
由完成的
添加一条评论
The Clock battery is a 1616 cell battery. It is found by removing the main battery and looking to the top of the battery chamber, here you will see a sliding cover which if you slide out of the chamber will reveal the battery. Nice simple one when you know
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
david bebb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 190
