Can I replace the memory (Microsoft surface model: 1868)
is the memory in any variant of the 1868 Microsoft surface replaceable without soldering or even WITH soldering.
Officially the answer is "NO" because they ARE soldered in place. Here is a link to a discussion on this topic, however, and it seems, Yes it is possible, perhaps one of the folks who does this sort of thing professionally can give a better answer, it seems there is more to it than just replacing the memory with the compatible puppies, though... the link:
这个答案有帮助吗?
@zivameyer you will also need to update and flash the BIOS otherwise your computer will not boot up with a change in memory. The soldering of the memory module will require a proper rework station.
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 168
