跳转到主内容
加入维修社区 - 创建账户
型号 A1419 / EMC 3070 / 2017 年中 / 3.4、3.5 或 3.8 GHz Core i5 或 4.2 GHz Core i7 Kaby Lake 处理器 (ID iMac18,3) / Retina 5K 显示屏。请参考较旧的 iMac Intel 27" Retina 5K 显示屏 (2014 年末及 2015 年) 指南,因为该系统的结构非常相似。
OEM hard drive replacement
What is the Kit for an OEM hard drive replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is this what you are looking for? SATA HDD to SSD upgrade or PCIe/NVMe Blade SSD upgrade
And here's the two guides:
The HDD drive swap-out is the easiest to do, but the Blade SSD offers better performance.
Do keep in mind if you have a Fusion Drive you have both drives present! And you will need to disable the Fusion Caching SSD (Blade Drive) otherwise you'll encounter issues as it wants to join the fun which you don't want!
The easiest way to disable it is once you have the system running open Disk Utility and make sure you select show all volumes so the hidden Cache drive can be selected and reformat it deleting it fully. Is mostly a useless drive as it's too small to effectively hold the OS.
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit.图片
产品
iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$115.99
Upgrade your iMac with a new SSD to dramatically speed up your machine.图片
产品
iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle
$249.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Core Solutions 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 16
总计 154
