跳转到主内容
加入维修社区 - 创建账户
2017 年 6 月,Apple 更新了其 13 英寸 MacBook Air,配备了更新的 Broadwell Intel Core i5 处理器,性能和电池续航时间均略有提升。
Replacing a burned USB Port
Same MBA from previous 2 questions. We ran a diagnostics after solving the charging issue and got a notice of a faulty thunderbolt with no output & a burned USB port. Upon closer inspection the outside of the port appears to be burned! Question is, can these be easily replaced by lifting them both from a donor board of the same model? Note that there is some sort of material shielding over the top which will more than likely 'melt', so do we just peel that off and then replace it with some tape to cover the holes below? Seems to be a straight forward transplant, but asking just to be sure.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I have yet to find a dependable way to replace most of the ports Apple has mounted on the main logic board. Sadly I always end up replacing the logic board. Between custom parts and the shielding some have to even get to the port to try to unsolder them and some have the mounting tabs bent so the board can be wave soldered so you need to unbend them otherwise you'll damage the boards layers.
这个答案有帮助吗?
得分 1
5条评论:
@danj I had a hunch there would be more to it than just a lift and drop..... I think we will try to remove one from an old donor board 'to see the process / snags involved' before anything else.... Knock on effects from a Faulty TBP
完成的
@danj It was the USB that was burned out, but no output on USB & TBP (Both on the right side). So, theoretically we need to use a solder sucker to remove the underside solder, then unbend the clips to remove the ports right?
完成的
@livfe - Are you reading on the boards USB port 5 volts? Which is expected. First check if the lines are shorted If not that's your focus if finding why it's not present. Without power any non-powered device won't respond when plugged in. And if there was a AC powered device plugged in the external devices USB lines need to be checked as they may be pushing in voltage into the system burning out the logic.
完成的
@danj USB port is now suddenly revived don't know how, but the TBP is still sleeping....
完成的
@livfe - Sounds like a cold solder joint issue within the 5volt line to the port
完成的
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 32
总计 322
