跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBook Air,换上了更新的 Broadwell Intel Core i5 处理器,使性能和电池续航时间略有提升。
Knock on effects from a Faulty TBP
... Continuing from my question regarding Replacing a burned USB Port
1 - Would a faulty TBP be a possible cause for a constantly maxed out fan
2 - Is there a way to just disable this part via some 'hidden' system setting?
3 - or IF we did manage to completely remove it from the board would that cause an issue if it were 'not replaced'? We haven't tested the TBP to see if it actually still functions but even if it does, we need to eliminate this issue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would check both continuity using a cable plugged in to the logic board, as well as checking the voltages per the Schematics & Board view drawings, and maybe on some lines compare the resistance to another working system.
这个答案有帮助吗?
得分 0
11条评论:
@danj I edited the Q as it kinda has 3 points in it, what is your opinion on them?
完成的
@livfe - I've not encountered a TB port failure like you have encountered so I can't tell you if the port is the issue or the circuitry behind it for sure which is why I was aiming you on how to test things.
1 - I would expect the ports logic was more likely the issue
2 - SMC sensors would be the trigger of the fan to go into over drive. Not the TB port it's self unless it was damaged. So disabling SMC would be the extreme. You might be able to clear the process load within Activity Monitor killing kernel_task items.
3 - The connector it's self is passive so removing it won't be an issue, but you do limit the system ability to access fast storage and leave a gaping hole.
完成的
@danj The TBP appears to be 'burned' inside where the connector would go, this is linked to a previous question Replacing a burned USB Port hence, why we have the need to remove it or replace it.... (3) The port I believe is not being used anyway, so we could just 'plug the gap' after.
完成的
@livfe - I understood that, but the cause of the ports damage is the deeper question! For the sake of argument let's say this person had an external AC powered HD drive and the Air was plugged into the same outlet but the plug was 180° so the hot and the common are shared across and the MagSafe charger was a cheap knock off the the power would jump across the TB outer shield (chassis ground on both sides thing would get toasty! It's also possible a lighting strike or power line surge messed you up. So was the damage limited to the port? Or was the circuitry affected? Clearly it was as the fan is running hard.
So yes! The port is damaged but that is not the worry as long as it doesn't have a short which gets back to the diagnosis of the problem checking the lines. Get an old TB cable cut one of the ends off and carefully figure out which wire goes to which pin and then reference the schematic and drawings to see what the line should be and also use a second good system to compare as well.
完成的
@danj Unit was using an original charger, board appears under the michael to have no blown components though we will be checking as much as we can, it is just quicker to just remove it in whole as I think the 'issues' are inside the port part and not on the board. Looks like an insect or something got in there on the train tracks and then the port was connected via the cable and it got badly hurt internally. Like you, I haven't encountered an issue like this before. I seem to be good (Or unlucky) to find these systems haha. (The fan issue maybe due to a bad sensor and unrelated), who knows, 1st to isolate this TBP somehow and see if it changed anything.
完成的
显示更多的6条评论
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 27
总计 208
