跳转到主内容
加入维修社区 - 创建账户
8BitDo Ultimate Wireless 是一款由 8BitDo 开发的无线游戏手柄。它于 2022 年 10 月 28 日发布。
Left joystick is spinning
Hi
I have a 8bitdo Ultimate controller and recently the left joystick has started spinning, which is really annoying.
What can I do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi!
Okay, either the joystick broke off and causing the thumbstick to get loose. Or it just went lose (hopefully this is it).
The only thing you can do is to open it up and check the joystick!
Guide: Disassembling 8BitDo Ultimate Bluetooth Controller - iFixit Repair Guide
If the joystick broke off, you should replace it. This requires soldering unfortunately...
Please let us know how it goes!
这个答案有帮助吗?
得分 3
2条评论:
If I need to make the bigger repair and replace the joystick part (a different mechanical malfunction), where would I look for replacement parts?
完成的
Aliexpress, Ebay or Amazon are your best bet. Also: you have most of the time, 2 different joysticks. A smaller one and a bigger one. Sometimes they are kinda universal. So you need to check first what you need.
完成的
添加一条评论
添加你的答案
Niki Rogalski 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 76
总计 753
