跳转到主内容
加入维修社区 - 创建账户
也称 PS2 ,是索尼于2000年3月在日本首发的第六代电视游戏主机。当年稍后时间登陆美国市场,机器型号为 SCPH-30000。维修这款设备只需用到常见的工具,但维修过程可能会有点难度。
Fat Ps2 Scratching discs?
Typically when discussing Ps2's that scratch discs, the slim is the first thing that comes to mind. I have however recently purchased an SCPH 50001/N model and noticed that mine is scratching discs a bit differently. After having searched many forums, I can not find so much information.
Here's the issue:
I have purchased games recently that were very clean (SCIII and SOE) and decided to pop them into the PS2. What I've noticed is that after 30 mins or so I receive a pattern of hair like circular scratches around the disc. Now keep in mind, these are not circles that ring around the whole disc, rather its a pattern of multiple circles around the disc. What could be causing this? If you need pictures I am able to upload but any help would be appreciated as I can't find anything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
Could be multiple things.
1: The laser is replaced and not correctly installed (in height).
2: The top case has been replaced with another one, but is the incorrect type/version.
3: Disc drive isn't alligned properly (less likely).
4: Something is stuck inside the disc drive causing scratches.
Did you recently repaired the PS2? Or did the previous owner?
Replacing the disc drive is a option, replacing the top case is difficult as there are many versions out there.
If you can share some pictures, that would be great!
这个答案有帮助吗?
得分 1
6条评论:
Hi there! Thank you for engaging with my post. I have just posted the pictures now. Let me know if you have any questions.
完成的
Hi!
Yes, I would replace the top cover of the disk drive. There are 2 main versions out there.
1: Top loader with 2 clips and 2 screws.
2: Top loader with 4 screws without clips.
You need the 1st one. The one with 2 clips and 2 screws. I would replace that one and see how that goes. If the same issue occurs, I would replace the laser and check afterwards.
Still facing issues? Then you most likely want to replace the whole drive.
Please let us know how it goes!
完成的
@dan0 Thank You. Just out of curiosity, do you see any issues with the top loader itself which causes you to suggest that?
完成的
My pleasure! No I don't. It's hard to see with the eye. I know from experience that the top loader is usually the culprit..
完成的
@dan0 Ok! I really appreciate your help!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Tom19 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 76
总计 772
