跳转到主内容
加入维修社区 - 创建账户
Bose QuietComfort 35 II(型号:789564-0020)是由 Bose 设计的蓝牙降噪耳机。该设备附带一个 USB 充电器和一根耳机插孔线缆,并兼容 iOS 和 Android 蓝牙设备。
How to replace the internal battery?
I have it for some years and the battery's duration is reducing as it's expected from rechargeable batteries. It's not lasting enough hours to use it for work. I have several online meetings so I need to replace the internal battery to make it last at least 8h of continuous use.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
After poking around the dark corners of the internet, I think I have enough information for you to accomplish your battery replacement. The first place I'd start with is the iFixit guide for the QC 35; after close examination it appears the process is identical for your QC 35 II, so this guide will get you there.
Bose QuietComfort 35 Battery Replacement - iFixit Repair Guide
Just to be safe, you can check out the QC 35 II audio jack replacement guide that'll show you exactly how to get the earpiece open; I didn't see any differences, but I mention this just to cover all the bases.
Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement - iFixit Repair Guide
One guy on Reddit also had suggestions on how to do that same replacement on your headphones, so it might be worth your time to take a look at what he had to say about it, and he added pictures as well.
Replaced battery of bose qc35ii after 4 years : r/bose
Finally, another guy posted a YouTube video of the whole process on a QC 35, but again it seems to be the same for those and the QC 45 models as well.
Replace Old Battery on Bose Headphones – Easy at Home! - YouTube
As far as parts go, the 35, 35 II and 45 all take the same battery, so you won't have any trouble getting a replacement; in fact, you can even buy one right here on iFixit if you want to support their repair efforts.
Of course, for the cost conscious there are several alternatives as well; I found sources on Amazon, AliExpress and eBay that would all work.
As you work, take lots of pictures and once you're done you can use them to create your own iFixit guide to your battery replacement. It's easy, fun and will earn you the respect of the repair community.
Create a new Guide - iFixit
Good luck, and let us know how it all turns out!
Replace a 600 mAh battery compatible with Bose QuietComfort 35 Headphones. Installations requires soldering.图片
产品
$29.99
Bose QuietComfort 35 电池图片
指南
Bose QuietComfort 35 电池更换
难度:
困难
45 minutes - 2 hours
Bose Quiet Comfort 35 II 音频插孔图片
指南
Bose QuietComfort 35 II (型号 789564‑0010) 音频插孔更换
难度:
困难
30 minutes - 1 hour
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tbazzi 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 40
过去 30 天: 154
总计 1,843
