跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 850 G2 发布于 2015 年,是 850 G1 的更新机型,配备了更新的处理器以及可选的触摸屏。你可以在此找到维修指南和详细信息。
My device doesnt powering on.
Device doesnt powering on..with battery or without battery, only charger.
When i press power on button,only keyboard lights turn on for a second, not ndisplay.after a second it turns off keyboard light too..
I opened the case.The fan spins when device got power.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
@dynamicrex does the fan spin normal, fast or just a little bit? What have you already checked?
由完成的
Fast spining fan
由完成的
Please Remove the RAM and check
由完成的
@dynamicrex Have you attempted to remove/reinsert the hard drive in addition to the RAM?
由完成的
添加一条评论
2个答案
This behavior usually points to a hardware power or motherboard issue. Since the keyboard backlight flashes briefly and the fan spins, the laptop is receiving power but failing POST. Try a hard reset first: unplug charger, remove battery, hold the power button for 30–40 seconds, then retry with charger only. Reseat RAM, SSD, and display cable. Test with one RAM stick if possible. If there’s no display even on an external monitor, the issue is likely a faulty motherboard, BIOS corruption, or power IC. In that case, professional repair or board replacement is required.
这个答案有帮助吗?
得分 0
添加一条评论
Well you can checkout the following video: https://www.youtube.com/watch?v=eHPTNKTg...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dynamic Rex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 136
