跳转到主内容
加入维修社区 - 创建账户
经典 Xbox 无线控制器的第三次修订版于 2020 年 11 月发布,与 Xbox Series X 和 Series S 一起捆绑销售。 该控制器向后兼容以前的 Xbox One 游戏机和 PC。
How can I remove stuck pin?
Pin is mushroom at the top, meaning no grip, but at the bottom it has grip. I used a desoldering gun and wick still didn’t work, so I got a hot air station. Still doesn’t work. Temperature I used was 300-400°C for 15 seconds or more, but it depends. Solder is lead-free.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Hi!
Are you able to upload some photos? This will make it easier for us to come with an answer! Thanks!
完成的
Mybad updated picture uploaded
完成的
@dan0, for equipment, I have an atten heating station, a Hako desoldering gun, and a soldering iron Hako 8888DX.
完成的
Thanks! Do you have a hot air station? Would try that and then try with tweezers to get it out. Make sure you use flux first. It should come out.
完成的
添加一条评论
1个答案
I would add flux and then solder, heat, and try to pull with tweezers. Might need to increase the heat as well. Hope this helps.
这个答案有帮助吗?
得分 0
2条评论:
I tried using that method to increase the temperature, but nothing happened. Is there a way I can demonstrate it to you on FaceTime?
完成的
I’m thinking about getting a another daughter board but at the same time what if that issue come up again
完成的
添加一条评论
添加你的答案
randy 098 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 210
