跳转到主内容
加入维修社区 - 创建账户
任天堂2DS是一台掌上游戏设备,作为任天堂3DS的入门版本而开发,在硬件上与3DS完全相同,但没有裸眼3D功能
2DS Volume Slider Not Working
I have a 2DS that's stuck on max volume. The first time I took it apart to fix the issue, the problem was that the plastic volume slider was loose and physically detached from the actual component on the motherboard, just like in this tutorial. I fixed that issue and the volume slider is now aligned, but when I adjust the slider, the volume still doesn't change.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi!
Can you put the volume slider to the lowest volume level and build it together?
If that isn't working as well (then you can say for sure it's there), you might want to replace it...
Soldering is required to get it replaced.
I think this one should fit: Amazon.com: Create idea 2pcs Game Consoles Volume Slider Switch Compatible with New 3DS 2DS XL LL Console : Video Games
Please let me know if you have any question!
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Louisiana Hesitate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 42
总计 369
