跳转到主内容
加入维修社区 - 创建账户
Olympus OM-1 于 1972 年发布,是一款极具革命性的 35mm 单反相机。它提供了一套专业级的全机械系统,且机身比当时市面上的竞争产品显著更小、更轻。该机型拥有明亮的取景器和独特的控制设计,例如环绕在镜头卡口周围的快门速度拨盘,而非位于顶盖上。
Maintenance question for OM-1N
I picked up a near mint OM1n from ebay, and i really want to keep it in mint working condition but where i live (island nation) there are quite literally zero shops that specialize in vintage repair/maintenance cameras, let alone Olympus systems. And i dont feel like sending it overseas.
My question is basically this, is there any guide/video tutorial out there that shows and explains a complete CLA process for the OM1 or similar cameras? Im aware im no technician but i can follow specific instructions on my own risk, specifically what kind of lubricants/grease to use, when & on which parts, how to disassemble exactly whats needed and put everything back together. I tried youtube but it doesnt go much further than light seal replacements and prism foam cleaning.
Basically the most basic maintenance a professional would do to prolong the life of the camera.
Or at least as much as a regular person with normal precision tools can perform at home.
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You can find the repair manual for your camera online as a PDF from a few sources. Scan example here's the older version Olympus OM-1 service manual here's the rest of the manual grab the last one gets into lube OM-1 & OM-4 maunals
这个答案有帮助吗?
得分 2
3条评论:
now where is a copy for the OM2n ?
由完成的
@om1gc - The mechanicals are the same across the OM-1 series. Only the metering and flash circuits are a bit different.
由完成的
@om1gc see if the manuals on here Olympus OM-2 under the documents tab will work for you.
由完成的
添加一条评论
添加你的答案
DBCooper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 64
总计 830
