跳转到主内容
加入维修社区 - 创建账户
A1297 一体成型机身型号:2009 年初、2009 年中、2010 年中、2011 年初及 2011 年末
How to get a new trackpad?
The trackpad gets harder and harder to use. It needs an unsual pressure to work. What can be done to fix it? Do I have to change the whole upper case? Do you carry them?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
Your trackpad may just have a loose set screw that needs adjustment. Here's a guide that may get you to it: MacBook 一体成型机身机型 A1342 触控板更换
这个答案有帮助吗?
得分 4
4条评论:
I was hopeful looking at that guide, that I could get my trackpad out to soak alcohol after milk was spilled on it. But I have the 17" model, and the ribbon cable for the trackpad is so securely glued to the top case that felt I would ruin it trying to get it off. Very disappointing that I'll probably have to buy the entire top case to fix this. But looking at the picture of the part (which is out of stock), it looks like no trackpad is included?? MacBook Pro 17" Unibody (Mid 2010) Upper Case
由完成的
Let me get this straight, you are going buy a whole upper case rather than replacing a cable that can be ripped out and replaced?
由完成的
Open it up and see if the battery is swollen and pressing against the bottom of the trackpad.
由完成的
Actually I will probably just replace the trackpad. I could not find the part here, but found it on powerbook medic.
The battery is fine, recently replaced. The trackpad had milk spilled on it.
由完成的
添加一条评论
If you're willing to be a little unorthodox, you can try placing a thick napkin on the trackpad, closing the clamshell, turning the machine over, taking off the bottom cover, removing the battery, and then add gently pour a little alcohol onto the underside of the trackpad near where the sensitivity screw is, toward the "front" of the case (closest to where the user would be sitting). Be careful not to get the humidity sensor wet (small white dot if it hasn't been triggered... maybe red/pink/yellow if it has been triggered). The napkin absorbs the excess alcohol as it filters through the trackpad. If it was just a small spill that caused the issue, the alcohol will clear out any goo, and the click function will work again. This worked for me with two computers.
这个答案有帮助吗?
得分 1
1条评论:
Weird. This is attributed to me, but I didn't write it. Bug in the system?
由完成的
添加一条评论
You will have to replace the whole upper case which can be purchased here.
Replace an upper case and backlit keyboard compatible with the Early 2011 model A1297 MacBook Pro 17 inch Unibody laptop.图片
产品
MacBook Pro 17" Unibody (Early 2011) Upper Case
$64.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Dudan 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 25
总计 5,815
