跳转到主内容
The Nokia 2630b is basic phone with a VGA camera.
4 个问题 查看全部
NOKIA 2630b BLIND SCREEN
AFTER A 80 CM FALL MY NOKIA 2630b'S SCREEN IS BLIND, BUT THE PHONE SEEMS TO WORK WELL. COULD IT BE A SCREEN BAD CONTACT ? IS IT POSSIBLE TO CHANGE THE SCREEN ? ARE THERE WELDS TO BE TAKEN OUT, OR JUST DISCONNECTING AND CONNECTING ELEMENTS ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Monteiro, all caps means you are YELLING ;-)
完成的
添加一条评论
2个答案
最有帮助的答案
Monterio, the first thing that you may want to do is to look at this guide It will show you how to get to your LCD. I would check for a lose connection of the flex cable. If it is still connected, look for any obvious damage to the logic board and the display. Replace the LCD if nothing obvious is found. You can also get the complete service manual for your phone from here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Hi,
First of all i would love to suggest you visit bb-parts.net and get relevant information about these topic.
Hope you will solve your problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Monteiro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 769
