跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
SSD disk for MacBook Pro
Hello,
Do you have a 1 TB SSD disk and 2 x 4 GB memory modules and at what price?
Sincerely,
Flemming
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hello,
Thank you.
Last 3 digits in my serial no. is F8X
Sincerely,
Flemming
完成的
添加一条评论
3个答案
已选择的解决方案
Your machine is a :
Apple MacBook Pro "Core i7" 2.2 15" Early 2011 Specs
Identifiers: Early 2011 15" - MC723LL/A - MacBookPro8,2 - A1286 - 2353-1*
It came with: Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: 4 GB of RAM is installed as two 2 GB modules, no slots free.
*Apple officially supports a maximum of 8 GB of RAM, but this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules. Supports 1333 MHz PC3-10600 DDR3 SDRAM.
The largest pure SSD drive that I am aware of as of this writing that will work in your machine is 512 GB Crucial :
http://eshop.macsales.com/item/Crucial/C...
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
I don't even think a 1 TB SSD exists for that size. The only 1 TB SSD that I think exists is the OCZ 3.5" drive, but that wouldn't fit into a MacBook Pro. That alone, in the bigger size, costs over $2500. The largest one that I have seen for your computer is 512GB in capacity. I recommend these solid state drives from amazon:
http://www.amazon.com/dp/B004W2JL3Y/ref=...
If you give me the last 3 digits of your serial number I can tell you where to buy ram.
Hope this helps.
这个答案有帮助吗?
得分 2
1条评论:
Here is the link to the 8 GB of ram that I recommend:
http://eshop.macsales.com/item/Other%20W...
完成的
添加一条评论
此回答最初是针对另一个问题
Anyplace you'd like. Here, ebay, google shopping. As long as you get the right speed and pins your good. It helps tostart with IDing your Mac.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Flemming Ast 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,834
