简介
升级硬盘,有更多存储空间!
你所需要的
将电池从主板上倾斜到足以触碰电池电路。
将电池电路从主板上的插座中拔出,然后从上盖取出电池。
把电池充满,然后至少继续充电两个小时。之后,像往常一样使用它,消耗电量。当你看到低电量警告时,保存好你的工作,然后让笔记本开着,直到它因为低电量而入睡。再等待至少五个小时,之后再把你的笔记本充满到100%
如果在安装新电池后你发现了一些异常状况或麻烦,你可能需要重置你的Macbook的设备管理器
请按逆序操作组装你的设备。
382等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
22指南评论
I went all over the place trying to find that stupid 7.4 mm Tri-Wing bit or driver to remove the battery per your instructions then I took a harder look and realized there was no need for all that SMFH!
Richard Vera - 回复 分享
We have you remove the battery because as long as it is connected, certain components on the logic board are electrified. If you accidentally drop something metallic on the board or touch the wrong part with a screwdriver, you could fry the board be out another $700+.
I bought the 1TB and the tool kit. Got it today. The step by step directions made it a piece of cake. Afterwards I booted up my MacBook Pro off of my system software cd. The new hard drive didn't show up so I called iFixit and talked to Scott. He told me how to format my drive and had me up and running in about 2 minutes. You guys are awesome! My computer works great and I went from a maxed out 500 GB hard drive to a full 1 TB Hybrid hard drive. Thanks for the new lease on life.
josephpass - 回复 分享
So, SSD´s can replace an the original HDD without any sort of fitting?
Nico Sauer - 回复 分享
