跳转到主内容
加入维修社区 - 创建账户
Operates automatically; out of control.
My Kobo Clara just operates itself automatically. It is out of control. It sometimes zoom in or out, choose its own book, or keep going back and forward. what I shall do to repair it in such situation?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
i have found the solution for this problem (ghost touch) for my kobo clara 2E.
1. factory reset
2. clean your screen using slow tap water then wipe with dry cloth
3. disable sleep for screen
4. power on your kobo and just let your kobo battery drain. then charge using the provided cable
mine solved after 2 cycles of step #4.
完成的
添加一条评论
1个答案
@maceylee33728 that is what is called "Ghost Touch" and is caused by a digitizer error. It looks like your digitizer is adhered to the LCD. In that case you would need to replace the complete display assembly. I have not come across any guides for this reader. You would need to take a look at all the Kobo devices and see if one of those at least comes close to yours. Maybe even look at something like this video
Looks like replacement screen are available at some online stores like this one (Example only and not an endorsement of the seller)
While you work on your ereader, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Macey Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 52
总计 392
