跳转到主内容
加入维修社区 - 创建账户
佳能旗舰级数码单反相机,于 2012 年 3 月发布。主要面向专业体育摄影师、野生动物摄影师和新闻摄影记者。
How do I replace the port covers?
How do I replace the rubber port covers on the 1DX ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I haven't replaced the IF cover for this particular camera, but I can answer based on my knowledge of other Canon cameras and what I'm seeing on the parts catalog for this camera.
It appears that there are three screws located under the rubber covers that you'll have to remove. Additionally, there is one more screw that is hidden underneath the front rubber cover. To remove this one, you'll just need to peel up the rubber cover slightly towards the top of it (the rubber cover is just held on with adhesive). Once those four screws are removed you should be able to pull it off. If you're having difficulties getting it pulled off, you may need to slip a plastic opening pick into the side of the cover to pop it off.
Below is a screenshot from the parts catalog which shows the IF cover and the screws that are holding it on (the screws that need to be removed are labeled as CB3-8227).
To aid with finding a replacement cover, the part number for it is CG2-3136 and the part name is the Interface Cover Assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pete Nagler 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 67
总计 697
