My fuses are ok, what next?
I have checked all the fuses and they aren't blown. My tv will turn on but the screen stays black and I can't channel up or down or see the menu. Do you think the power board is out? How can I test it?
MikieP, I can only assume that you checked the power supply when you checked all the fuses. For a great guide and a location of the fuses, check on here. There is also a great video tutorial on here. Also check the caps on your board. They do have a tendency to blow. The tops should be flat, not bulging, and there should be no leaky residue. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,205
6条评论
What else have you tried so far? Do you have any sound at all, but no video? Try and post a couple of images of your boards on here so we can may be try to "look" at your TV. You do own a multimeter etc? Do you have access to the service manual?
由 oldturkey03 完成的
I have looked over all the boards very closely and do not see any leakage or capacitors blown/bulged. I do own a multimeter (thats how I checked the fuses) but after the fuses I don't know what else to check to determine what the problem is..
由 MikieP 完成的
the only manual I have it the owners manual and it's no help at all
由 MikieP 完成的
Start off with getting the service manual from here. Did you check the link for the location of all the other fuses?
由 oldturkey03 完成的
Yes, I checked all the fuses and they are not blown. When I tried to view the link you provided I got this message from keep and share-
You (account name 'mikiepdizzle11') have just tried to access a document in another KeepandShare account 'oldturkey_manuals'. To view it you need to ask the owner of the other account to set the Sharing controls to give your KeepandShare user name 'mikiepdizzle11' rights to view the document.
由 MikieP 完成的
显示更多的1条评论
