跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch 2的维修指南,拆解信息,以及故障排除方法。该机器是2017年至2021年销售的 Nintendo Switch 的后继机种。发布于2025年1月,并于2025年6月5日正式发售。
Using Switch 2 without any Bluetooth when docked?
With the first generation of Switch (which I’ll call “Switch 1”), it is possible to use the console in dock mode (plugged to a TV) while preventing the console to emit Bluetooth. As documented there in the last two comments, all you need to do is use only a wired controller and enable the setting that forces it to communicate with the console via its cable.
I’m wondering if the same thing could be done on Switch 2.
The user manual says that, when docked, the console always activates its Bluetooth antenna. This behaviour is identical to Switch 1. However, I suspect it does not emit any signal as long as no wireless controller tries to communicate with it. This is how Switch 1 works, thus enabling to play in docked mode without any Bluetooth.
I contacted customer support at Nintendo. Twice. But the persons I got in touch with did not understand my question, and replied that I “just need to turn off Bluetooth”, which is impossible when the console is plugged to a TV (as Nintendo’s own user manual says).
A friend of mine confirmed that the setting to force wired controllers to communicate via their cable is still present on Switch 2. So the only remaining question really is to know whether the Bluetooth antenna stays silent as long as not wireless devices tries to communicate with it, exactly as Switch 1 did.
Thanks for any help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
8条评论:
Hey dude, did you find that connecting a wired controller stopped the bluetooth transmitting?. I just purchased a switch 1 and would like to stop bluetooth transmitting and it would be nice to know if when I buy a switch 2 I can also stop the bluetooth transmitting.
由完成的 分享
Hi!
You cannot turn off the Bluetooth for a Switch 2. The only way is to put it in Airplane mode, but this will disable Wi-Fi as well. May I ask why you want to turn the Bluetooth off? Thank you!
由完成的 分享
Just personal reasons. Apparently when on airplane mode it will still send out a slight signal, it does not turn off completely. Do you know if this is correct or not?.
由完成的 分享
Nope, should disable all the signals. Due security meanings (like in Airplanes) it's not allowed to transmit or receive any data signal when turned on. This should be related to every device out there as it could be in conflict with security implications.
Regarding iPhones, when Airplane mode is turned on, you can still turn on Bluetooth, Wi-Fi, ect apart from it. But this requires manual input. Again, this is not recommended in some cases.
For the Switch 1 or 2, it should disable all communication options.
由完成的 分享
Ok, thanks but can you do that when it is docked?.
由完成的 分享
显示更多的3条评论
添加一条评论
2个答案
Hi Loïc!
Correct. The Switch 2 has the option to force wired controllers to communicate via cable.
Bluetooth IS enabled, but is not transmitting everything when there are no controllers connected through Bluetooth.
You cannot disable Bluetooth entirely unfortunately. You CAN enable airplane mode, but this will disable the wifi as well.
If you have any more questions, please let me know!
这个答案有帮助吗?
得分 0
添加一条评论
With an RF meter, I've tested the Switch 2 docked with both joycons attached, connected to ethernet (no Wi-Fi connection), while using the Switch 2 Pro Controller wired. The console and controller do not emit bluetooth or any wireless signals even up close. I didn't need to manually press a setting in the Switch 2, this was automatic. If sensitive to magnetic frequencies, I haven't checked if the HD rumble 2 vibrations emit much but that can be turned off in the settings.
这个答案有帮助吗?
得分 0
1条评论:
Greatly appreciated dude. I will now be able to buy the new Zelda Switch 2 with a little less stress, thanks for that. What did the RF meter set you back cost wise?.
由完成的 分享
添加一条评论
添加你的答案
Loïc Lambert 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 62
总计 499
