跳转到主内容
加入维修社区 - 创建账户
20英寸、23英寸和30英寸铝合金LCD显示器,由Apple于2004年6月推出。型号分别为A1081、A1082和A1083。
Large Yellow Bar Running Vertically
I purchased this display used, and I haven't had any problems with it until recently. A thick, faint yellow line has been showing up vertically through my screen. Restarting and unplugging hasn't worked. After it's been on a while, sometimes it will disappear, but lately—it's been staying all work day. Does anyone know what's causing this? Photos below!
Photo #1: Screen with yellow line issue.
Photo #2: Original cord has electrical tape on wire. (I bought it like this.)
THANKS!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Howdy there, has the display been moved in a way that could have damaged it? Also is this the display the 27" model that only have the thunberbolt and magsafe connector shown here?
由完成的 分享
@jmehnert - These are the older DVI connection and you need a DVI to mDP port or Thunderbolt port adapter.
由完成的 分享
@jmehnert Hey! Thanks for your reply! Yes, it's the 27" model. Your link took me to the main "repair" area—I didn't see a specific magsafe connector image to compare the two!
由完成的 分享
@danj I'm not sure I follow. I have my Thunderbolt connected to my computer using this adapter: https://www.apple.com/shop/product/MYH93... It's been fine until now the yellow bar is showing up.
由完成的 分享
@reneeswigert - This is the older DVI model, yours is a TB2 with a TB3 adapter for your systems USB-C connection. As it turns out the TB3 interface offers multiple services old USB, mDP and USB-C based as well TB!
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
This is a kind of TAB error when the LCD glass and the flex cable are bonded together a connection can get broken which in this case causes the yellow bar. Sometimes massaging the interface can get it reconnected. But that will require a bit of disassembly to gain access to the back of the LCD panel.
While the cord is cracked which is likely why it's taped, you might be able to locate a replacement cable.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the insight! I'm pretty handy (as long as it doesn't involve soldering!), and I don't mind opening it up per the ifixit instructions I saw. I picked this monitor up for $150, so I don't have that much into it. Can't hurt to try!
由完成的 分享
Hi Renee, have you fixed the yellow lines? I'm having the same issue with my Thunderbolt Display
由完成的 分享
添加一条评论
添加你的答案
Renee 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 35
总计 398
