Why am I getting weird artifacts?
As the picture shows, there are white dots on the external display, the internal display is broken. These dots are not still, they move around the screen and sometimes a large part of the screen sometimes is covered in artifacts of all colors. This stopped for a short period of time where it connected and worked flawlessly and began again going into recovery mode and now I cannot stop it. Now with these arficats, it does not connect well and disconnects from the HDMI often. Any help is appreciated, thank you.
3条评论
@danj Is this a sign that the Internal graphics are failing? As I have also noticed this happen on an older Macbook model that I had here recently......? The internal display not working can be the flexgate issue https://www.lappymaker.com/blog/flexgate...
由 livfe 完成的
@livfe - This is not a FlexGate issue (backlight failure) or some other version of it effecting the video. From 2016 onwards the logic board pumps out iDP or eDP signaling to the display to then convert to the raster image (T-CON). Pixel lice is either within the RAM or at the T-CON not in the transmission between.
由 DanJ 完成的
One thing I'd also check is whether the artifacts appear before macOS fully loads, such as during startup or in Apple Diagnostics. If they do, that usually points away from a software issue and more toward a hardware fault. Since the external display is showing the same pixel artifacts and randomly disconnecting over HDMI, I'd suspect the GPU, VRAM, or display output circuitry on the logic board before replacing the LCD. A board-level inspection is probably the next logical step. I found this troubleshooting guide useful for similar laptop and MacBook repair cases: https://itworldthecomputeritsolution.in/...
由 DURGANAND 完成的
