跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 840 G3 的维修信息。这款惠普笔记本电脑专为企业应用而设计。
My display is glitching
I don't know if the problem is with the display or the RAM I will try to connect a external monitor later. When I am using the laptop while glitch screen it seems to get worse but it doesn't seem to compromise with the performance I hope it is an easy fix i think it's the problem with the display because few days ago I was carrying the laptop in my bagpack which was heavily packed
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@arzaanali "glitching" i really not anything that describes what issues you are having. You do want to go ahead and give a better description of what the issues with your screen are.
由完成的
添加一条评论
2个答案
已选择的解决方案
Hi @arzaanali
Try this....
go to:
https://ftp.ext.hp.com/pub/caps-softpaq/...
Use HP Image Assistant (HPIA)
to download the correct drivers and bios update on your pc.
Run the tool and click Analyze
Allow for some time to capture system configuration,
and install all packages that was listed on it.
这个答案有帮助吗?
得分 2
1条评论:
I HATE HP the next day the glitching problem was solved but today the laptop is not starting when I plugged it in the capslock button and the power button keeps blinking pls help
由完成的
添加一条评论
My laptop display is glitching, likely due to physical pressure while in a tightly packed backpack, and although performance remains unaffected, I suspect a display issue and plan to test with an external monitor.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arzaan Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 442
