跳转到主内容
加入维修社区 - 创建账户
2.0 GHz、2.3 GHz 或 2.6 GHz 四核 Intel Core i7 处理器(Turbo Boost 最高可达 3.8 GHz),配备 6 MB 共享三级缓存。
MacBook not turning on
Hey all! I was installing macos mavericks on my macbook, when it suddenly turned off and refused to turn back on again. The charging indicator shows that its charging thogh (the orange and green light) but isnt actually on. What can i do to fix it or what can be the cause? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Let's try a hard SMC reset.follow this guide to Step 2013 年末期带Retina显示屏 MacBook Pro 15" 电池更换 now with nothing plugged in press and hold the power button for a good 15sec's this will discharge the logic board. Now carefully plug in the MagSafe charger only, the system should spontaneously restart, let it complete the process and do a clean shutdown. Now carefully reconnect the battery and with the MagSafe charger also connected see if that works if it does, shutdown and disconnect the charger and test again. If any of these fails let us know.
这个答案有帮助吗?
得分 0
3条评论:
Hey til what step? I think your text glitched a bit
由完成的
I figured it out and tried your steps. Didn't work. However when i plugged the charger in and let go of the power button, it turned green, then it went back to orange
由完成的
@zarrar_ - I if it stays Amber, the battery needs to be charged and might need replacing as well. Let it sit a good four hours, then try to turn it on then.
由完成的
添加一条评论
添加你的答案
Zarrar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 23
总计 216
