跳转到主内容
加入维修社区 - 创建账户
芯片里面有什么?它怎么工作?电脑芯片也叫做集成电路、单片集成电路、IC、芯片或微芯片。
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
由完成的 分享
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
由完成的 分享
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
由完成的 分享
添加一条评论
1个答案
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
由完成的 分享
添加一条评论
添加你的答案
TechVid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 260
