跳转到主内容
加入维修社区 - 创建账户
Asko Appliances AB 是一家瑞典公司,生产冰箱、洗碗机和家用洗衣机等家用电器。公司总部位于瑞典西约塔兰省瓦拉市的 Jung。Asko Appliances 目前归 Gorenje 集团所有,后者是中国大型家电制造商海信的一部分。
What is the Error code E10
what is the Error code E10 for Asko Dishwasher and how to fix ir.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
What is the model number of your dishwasher? Asko makes quite a few different ones, and getting you the correct answer depends on which one you have.
Knowing the model number is essential in this case, as a general search for Asko dishwasher error codes shows that most Asko DW's use error codes that start with "F" rather than "E", so we'll need to confirm.
The only result I came up with that seems to be close is a video on YouTube describing an Asko DW with an E10 error code. They claim it's a water level sensor error, which could be the sensor itself, the wiring going to it, or an issue with the control board. The only real helpful information they have to offer is to tell you to turn off the dishwasher, unplug it for a full minute, then plug it back in and see of that helps. If not, they say you should then call a technician. :-/
E10 Error on Asko Washing Machine - How to fix - YouTube
Update (04/10/25)
A search for Asko documentation on your dishwasher turned up a user manual, which includes a troubleshooting section listing error codes.
User manual Asko DWCBI241.S.AU (English - 46 pages)
Here's the information relevant to your problem.
The Care and cleaning section has this information on clearing the drainage pump.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your prompt reply. Sorry, the error code would be F10 and model number is DWCB1241.S.AU
由完成的
添加一条评论
添加你的答案
Rashedul Alam 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 42
总计 445
