跳转到主内容
加入维修社区 - 创建账户
3rd party Gamecube Memory Card doesn't read saves
Whenever I try to use the memory card in a game it says it's damaged, and in the settings it says: "The device inserted in Slot A cannot be used."
The only thing that happened to that memory card was me moving it from my Gamecube to my Wii occasionally.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Which model of GameCube is it? (If it has a Digital AV out, it's a DOL-001. If not, it's a DOL-101.) I'm not sure if it would make a difference, but it might. Does it still function on the Wii? That could also make a difference.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi!
Do other memory cards works fine?
I would try this first before you are going to replace the front panel.
If so, then I would replace the memory card and get rid of the broken one. It won't be easy to fix that one unfortunately...
这个答案有帮助吗?
得分 1
2条评论:
I did end up replacing the memory card with 2 old used official ones from eBay which are still working now a year later.
完成的
Glad that a new memory card did work! Have a great day :)!
完成的
添加一条评论
添加你的答案
Nirby 74 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 32
总计 202
