How to repair GPU
GPU killed itself about 2 years ago and I've found no one willing to repair/replace it or tutorials online. If it really is impossible to fix, how should I go forward? This thing has too much precious data to lose
@turkeylegs on your 360 S the GPU is part of the CPU. It is not impossible but will require to have the tools to do a total reball. That means you would at minimum need the stencils, a BGA reflow machine and a new processor. That is where you run into trouble. Those do no longer exist. That means you would need to use an old/used processor. Nobody can/will work with processors that nobody knows anything about. Think about it, you may be buying somebody else's problematic chip.
这个答案有帮助吗?
I totally agree! So, the best thing to do is to buy a known working motherboard in this case. It IS more expensive… but will save you a lot of time as it is way easier!
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 173
2条评论
@turkeylegs lets see if our game console Guru @dan0 has any ideas on this one.
由 oldturkey03 完成的
Sorry for the late response again, my friend.
由 koppie007 完成的
