跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
MacBook screen white out? glitching?
hello first im korean so my english maybe not perfect sry :(
i bought used macbook pro 2015 15inch (since last macbook i bought wasnt able to fix)
i installed oclp (opencore legacy patcher) and bootcamp windows
everything works fine on windows but on mac os screen crackiling? glitching? like broken tv for 1sec and sometimes screen just turn to white or other color (gray,brown,rainbow etc)
i thought this happened after i install fmrte(i have to disable sip to lunch it) so i deleted it + return sip to normal but it wont work
have anyone know what cause it or how to fix it
thank u for reading long text
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I’m a bit lost here, are you running Windows or macOS and which versions as well as when, lastly, what are the Apps you are using.
这个答案有帮助吗?
得分 0
8条评论:
1. Windows 11 and mac os ventura 13.7.3
2. Fmrte is game editor I'm not sure but I think this glitching thing happened after I install and disable sip
3. I don't know this is related after enter password on mac os screen blink 1~2 times
完成的
@srywhytnecqrdkc Try installing https://app-cleaner.com/ this app, select expert mode, allow access when prompted and it will remove ALL the associated files from this editor (or any other app for that matter) and see if that makes any difference. Also check for any remaining files after emptying the trash and a re-scan....
完成的
Thnk you for advice I will try right now
完成的
@srywhytnecqrdkc - Which OS are you used for Fmrte? I would focus in on that OS first.
完成的
Ventura 13.7.3 mac os installed with opencore legacy patcher
完成的
显示更多的3条评论
添加一条评论
添加你的答案
장우석 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 55
总计 55
