跳转到主内容
加入维修社区 - 创建账户
Chevrolet C/K 正式名称为 Chevrolet C/K,是通用汽车生产并以 Chevrolet 和 GMC 品牌销售的系列卡车。C/K 系列包括皮卡、中型卡车和重型卡车。
Water pump replacement time
Water pump replacement timeframe
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@kodyarnold what is the year, the model and what engine size?
由完成的
添加一条评论
1个答案
已选择的解决方案
When it starts leaking or making noise. I'm not aware of any kind of recommended replacement interval like there is for timing belts or oil changes.
Update (03/13/25)
No problem, Kody. I don't know the details of your rig yet, but on my son's 1985 GMC High Sierra (K2500) with a 350 ci engine, it's a pretty straight-forward job. Once you have the belts out of the way it shouldn't take more than a half hour or so; add another half hour for the belt R&R and an hour should be enough time.
这个答案有帮助吗?
得分 0
3条评论:
I meant the time frame to actually fix it not when to replace it my bad
由完成的
Yeah sounds about right it’s a 98 but it’s also a 350 so I assume not much change besides maybe the water pump part itself but I believe they are in the same common area
由完成的
@kodyarnold Yep, not that much difference in that area. If you've ever had to replace a water pump on these new models that use the timing belt to drive the pump, now there's a pain in the behind. I'd much rather have one out there sitting proudly on the front of the engine where you can actually get to it. On my son's truck I can climb on in the engine compartment to work on it.
由完成的
添加一条评论
添加你的答案
Kody Arnold 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 274
