跳转到主内容
Apple 智能手表的维修和拆卸指南。
20 个问题 查看全部
Transfer of parts from icloud locked watch
What are the possible parts that i can transfer from an Icloud locked iwatch ( using it as a donor watch).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
screen, battery .. pretty much anything but the logic board. Maybe also simpler components on the board.
这个答案有帮助吗?
得分 1
1条评论:
To add to Xavier answer,
The series and size and if cellular, the watches will need to match up. You will loose NFC if you swap over the display assembly.
There is very little you can transfer, and most want to reuse the most expensive element the SIP module which is locked.
完成的
添加一条评论
添加你的答案
Gowtham Yarramati 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 20
