跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 个问题 查看全部
checked everything and still no power
have checked power to everything and still no power, its not the door switch because the inside light is not even on, and the themal switch is good, and i have power to the dryer everywhere it just will not do anything, please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Try unplugging it for 5 minutes to reset it, then plug it back in. Remember an electric dryer runs off of two 110 lines in the USA. So throw both breakers at the breaker box to be sure it's getting full power.
这个答案有帮助吗?
得分 3
添加一条评论
Your drum light is not a good indication that the door switch is working. Actually, if your door switch is not working, your drum light will not receive any power. Check the wiring diagram on your original question.
这个答案有帮助吗?
得分 2
1条评论:
Update? My dryer isn’t getting power either
完成的
添加一条评论
Tried everything you recommended and still nothing. Surly someone has solved this problem. Who has the answer. Percy 601-638-1646
Update
checked power to dryer, thermal fuse, door switch all ok. this dryer was working fine one day and nothing the next. No lights or anything just dead.
这个答案有帮助吗?
得分 0
3条评论:
What symptoms does your dryer have? What have you tied so far? What have you checked?
完成的
If you already checked all the parts and found them to be in working condition, I recommend a new control panel assembly.
完成的
How do you test a control panel board, My unit has exact same problem and board loos to the eye as good as new. gordo89120@gmail.com Control board is expensive $180 on Amazon, though it is an easy repair. But costly if that is not the problem.
完成的
添加一条评论
添加你的答案
kory hentges 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 2,027
