跳转到主内容
A gaming PC is a personal computer specifically designed and optimized for playing video games.
PC will not boot up
I hit the power button, fans turn a few times but won't start up. Sometimes the RGB lights turn on but nothing else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @zombieslay72601
What is the make and model number of the PC or motherboard if it is a custom build?
完成的
添加一条评论
3个答案
It’s sounding like your PC is having a power issue. Here are a few troubleshooting steps to attempt:
Check the Power Supply (PSU)
Make sure that the power cable plugged into the wall outlet and into the PSU is firmly in place.
Use an alternate power cable or wall outlet.
If you have a PSU switch (I/O) turn it off and on.
If possible test with another PSU.
Check for a Short Circuit
Turn off and disconnect everything.
Open your case
这个答案有帮助吗?
得分 0
添加一条评论
Well you can try the following:
  1. Try a different power source.
  2. Check your monitor connection.
  3. Disconnect your devices.
  4. Listen for beeps if any coming.
  5. Start your PC in safe mode.
  6. Restore your computer to previous settings. .
  7. Check for unresponsive apps.
  8. Unplug USB devices.
这个答案有帮助吗?
得分 0
添加一条评论
Your PC may have a power supply, motherboard, or RAM issue. Try these steps:
  1. Check power cables and connections.
  2. Test with a different power outlet.
  3. Reseat RAM and GPU.
  4. Clear CMOS by removing the battery.
  5. Test with another PSU if possible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zombie Slayer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 50
总计 101
