跳转到主内容
加入维修社区 - 创建账户
Shark Matrix RV2310 是一款于 2023 年发布的智能自清洁扫地机器人。
How to replace the brush motor
My roller brush motor is no longer working well. Keep getting the error that the brush is stuck. I have another unit that broke for a different reason and would like to swap the main brush motor, but would like instructions on how to remove and replace the motor on this model.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
this might help.
这个答案有帮助吗?
得分 0
添加一条评论
All of the videos on YouTube help you get apart the rest of the machine, except none tells you how to take the top of the shark matrix off. we found it easier to peel back the sticker top to get to the clips easier that you have to release to take the top off, see pictures.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem as well. You will need to do a near complete teardown of the robot to get to the motor/gear assembly. Its pretty straight forward of you have the tools necessary. The only hidden aspect is the lock ring on the top. You need to remove the “Matrix” circular emblem off the top and then you get to that lock ring.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hanovaman 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 81
总计 1,187
