跳转到主内容
Nokia手机的维修指南,包括智能手机,以及大量的标志性“砖头机”。本目录中不包括使用Android和Windows操作系统的Nokia手机。
Nokia 7100s data cable use
I have a Nokia 7100s phone which I bought about 15 years ago. Several years ago I also acquired the special data cable that fits into the socket between the charging and the headphone sockets. However, when I plug the USB end into my Windows 11 computer, nothing on my computer recognises anything has changed.
I would like to see if I have any pictures or videos which, although deleted, I might be able to restore with the proper software. Is there any way of getting access to whatever program Nokia engineers used with the above-mentioned cable? Or is there another way of doing it? Come to think of it, what was that socket and its corresponding cable for in the first place?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @davidyoung13979
Seems like you need to use the data cable that is used with the phone.
If you have got it anymore, search online for CA-112DS to find suppliers that suit you best. (examples only)
Update (01/30/25)
Hi @davidyoung13979
The cable is designed to be used in conjunction with an FLS-5 adapter (see image) and it is used for flash programming the phone using proprietary software.
I can't find any suppliers for it online.
The phone's user manual doesn't specify that it can transfer stored user data via a cable connection. It does say that a Bluetooth connection can be used to do this.
(click on image)
Update (01/30/25)
Hi @davidyoung13979
Don't know if you're interested but here's the service manual and the schematics for the phone.
这个答案有帮助吗?
得分 1
3条评论:
I specifically said in my original post that I acquired the data cable a few years ago.
My question is about how to use the data cable, as nothing happens when it is plugged in to my computer.
完成的
Thanks for the information on the FLS-5 adaptor.
完成的
Excellent! Those two manuals will be useful. Thanks.
完成的
添加一条评论
添加你的答案
David Young 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 51
