跳转到主内容
加入维修社区 - 创建账户
第二代 Sony PlayStation 5 DualSense 手把的維修指南、拆解說明與故障排除資訊。 可透過型號 CFI-ZCT1W 及主機板型號 BDM-020 進行識別。
X button sticks slightly
X button is harder to press and stays down for half a second, took it apart and cleaned it with isopropyl. Worked great until I used it for about an hour. Same problem, cleaned again. Working for now but I need a more permanent less time consuming solution.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi there!
Yeah, cleaning is basically the solution for this. However, if the issue remains after cleaning, then you might want to replace some components.
I would replace the “X” button and the rubber pad as well. Replacing those should deal with the sticky button right away.
这个答案有帮助吗?
得分 1
3条评论:
Thanks I'll try that. What's a good brand/website for those components?
由完成的 分享
You can find the parts on AliExpress!
Some examples:
Buttons: https://www.aliexpress.us/item/325680635...
由完成的 分享
Rubber pads: https://www.aliexpress.us/item/325680437...
Good luck with the repair!
由完成的 分享
添加一条评论
添加你的答案
Topcat 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 16
过去 30 天: 37
总计 634
