跳转到主内容
加入维修社区 - 创建账户
于 2004 年 12 月 12 日在日本发布,2005 年 3 月 24 日在北美发布,并于 2005 年 9 月 1 日在欧洲发布。
PSP 1001 Right Trigger Unresponsive
Basically I haven't used the PSP in some time and after starting it again I noticed the right trigger is toast, doesn't respond to any clicks.
Anyone know what might fix that?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Alex!
Someone did made a video about how to fix this!
Link: https://youtu.be/edSyysTaAGg?si=0MtDtEgR...
Part:
https://a.aliexpress.com/_EzjnG9i
I repaired many of them and it’s easy! You need to replace the whole flex cable and after this it should be fine.
You need the PSP1000 one. If you have any questions, please let us know!
这个答案有帮助吗?
得分 1
8条评论:
Interesting! I'm a little indimitated at how many parts seem to be in the console but I'll see if I can give that a shot. I'm guessing it's more or less you unscrew the whole thing and simply replace that part you order for it?
Thanks!
由完成的 分享
Hi Alex! Yes that is correct. You need to take the front cover off, then the home button, volume buttons, etc bar, be careful to take it out the connector, all of them are very fragile. And then remove the LCD (it's still connected to the motherboard, so again, be careful). Then take the right board out. Follow this guide: PSP 1000 主板更换 (till step 16) and then put the new part in and reassemble it again. Good luck and be careful!
由完成的 分享
Gonna aim to try that. Thanks Again!
由完成的 分享
My pleasure!! Good luck with the repair!
由完成的 分享
I replaced the cable on my own psp 1000. All the buttons work with the new cable except for the right trigger (the one I was trying to fix). Any ideas an what to do?
由完成的 分享
显示更多的3条评论
添加一条评论
添加你的答案
Alex Reichmann 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 20
过去 30 天: 98
总计 1,658
