跳转到主内容
加入维修社区 - 创建账户
Texas Instruments TI-84 Plus 计算器支持。
Line of keys not working.
I've had my calculator for years and use it frequently. Today, an area of keys - specifically "0", "1", "4", "7", ",", "sin", "apps", "x^2", "(", ")" stopped working. All other keys work fine. I've tried restarting, system reset, and changing batteries. I don't know if it's possible water damage (I have cats) or something else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If a column of keys stops working that typically means it's a hardware problem. You might have success taking the calculator apart and cleaning the button side of the circuit board with isopropyl alcohol.
However, it's likely you'd also need to do a board level repair using soldering equipment. Water damage and corrosion can certainly cause issues like this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Milo Moss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 137
