跳转到主内容
加入维修社区 - 创建账户
Power Mac G5 是苹果公司于 2003 年首次生产的台式电脑。本指南将介绍 2004 年款 Apple Power Mac G5(型号 A1047,EMC 2061)的维修流程。 它于 2006 年停产,当时正值苹果从 PowerPC 架构转向 Intel 架构(首先面向开发者,随后面向消费者)。
Cannot connect (mount) as server for MacBook Pro (new)
We have had a lot of trouble mounting servers between my desktop and laptop computers. Originally we had no problem at all. We could mount and do screen sharing at will. Later, we could not mount the desktop on the laptop. Now we cannot mount either on the other - tho can always see listed in the finder.
I get the following Msg:
The Finder cannot complete the operation because some data in "afp://10.0.1.4/" could not be read or written.
(Error code -36)
Of course I have been over the sharing settings many times.
Anyone have any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
How are you connected?
完成的
Sorry folks - I did not realize the the 2 machines would not appear inside my msg. One is a Mac Pro G5, other is a new MBP - All running Leopard: 10.5.8.
Connect via Airport. G5 is wired.
Again, I have triple checked the System Pref settings a dozen times. (tho this still does not preclude the problem being totally obvious.)
Like I said - it all used to work just fine.
完成的
添加一条评论
4个答案
已选择的解决方案
Well - the system does not let you answer your own question so I had to make a new account.
Answer:
I called Apple Support. WOW that was easy!! I can't believe how easy. Of course I was going to have to pay since the machine is so old (6 years), but since I had upgraded the OS to Leopard, it was FREE!
- First call:
They said run "Fix Permissions" from the Disk Utility app. Then in Sys Prefs>Sharing turn OFF all sharing - do a restart - then turn them back on.
This was a good idea but did not work.
- Second call:
So I went back online and got an immediate slot - no waiting!
Solution:
SysPrefs>Security: Firewall tab:
There are 3 Options:
- Allow all incoming connections
- Allow only essential services
- Set access for specific services and applications.
The problem is that the list box is visible even when #2 is selected so it looks like the items are available. But they are not.
So I set to option #3 and was able to connect.
Not sure when my machine got changed, the other was probably changed at wife's work.
Hope this can help others.
BTW - Screen Sharing is awesome. Allows me to do a lot of compute intensive jobs on the faster machine while still on my main old G5.
这个答案有帮助吗?
得分 1
1条评论:
You should be able to answer your own question; the site just warns you about it before you submit. Also, thanks for posting your solution!
完成的
添加一条评论
Do each of these computers have assigned Static IP Address's? it not 10.0.1.4 may not be the computer you think it is..
if you don't like the idea of static, the next best thing would be to setup a DHCP reservation in your router. that way the router always assigns the correct IP address based on MAC address.
这个答案有帮助吗?
得分 0
4条评论:
Can you make this easier to understand for a layman?
完成的
NO - I did check the IP first. That - of course - was trying to connect via the Finder "Connect to..." command. But if I try to connect by clicking on a Finder Window Sidebar (i.e. the icon for the other computer) then I get even less feedback - only "Failed."
But thanks for the idea.
完成的
Are they Both Macs?
完成的
Well - I finally got off my duff and put in a call to Apple on it. It has been a pain for a while - but never got up the energy to deal with it :)
Thanks to you all- now I have.
完成的
添加一条评论
This page will explain to you how to fix your problem.
这个答案有帮助吗?
得分 0
4条评论:
He wouldn't be using AFP if it was a windows computer.. or perhaps thats the issue?
完成的
Thanks again - but did not.
That was for connecting to a Windows server with SMB. Mine was an attempted AFP connection.
完成的
Both are Macs - used to be able to connect no prob, even screen share. NOw nothing.
完成的
My bad for not catching that detail, but it's the same error message so it'd be a similar cause. Have you by any chance changed the password on the computer?
完成的
添加一条评论
I'm just a regular computer user who doesn't know the difference between AFP and SMB. I usually connected to a shared network at work through AFP. However, I recently couldn't connect to the network and got error code 36. BUT when I tried changing from AFP to SMB, I was enable to connect to my network once again Yay!!!....just so you know....hope this helps
........POP.........
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jmmx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 3,725
