跳转到主内容
How do I boot into bios
Every google result tells me how to boot into bios on a normal laptop, with function keys. This laptop doesn't have those.
An answer would be appreciated. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @jeff___
Chromebooks don't have a BIOS like other PCs as they use the Chrome OS to function
Here's a link that describes it better than I can.
这个答案有帮助吗?
得分 2
12条评论:
Hi Jayeff,
Thank you for your response.
Is there an equivalent that is available on Chrome OS?
Thanks
(W name btw)
完成的
@jayeff above
完成的
@jeff___
You need to have a laptop that is working to access the BIOS info in Chrome OS.
Here's a link
完成的
I do have one. The post that you attached does not mention anything about using another device. How would I use another device to get the BIOS of my Chromebook?
Thanks.
@jayeff
完成的
@jeff___
I meant that to access the BIOS in the laptop, it needs to be working i.e. able to be turned on and the OS loaded OK etc.
My comment was based on that you asked another question, previous to this one, on the same day, for the same model, where you said that it will not boot.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 26
总计 121
