跳转到主内容
加入维修社区 - 创建账户
1.86GHz 或 2.13GHz 处理器,128GB 或 256GB 闪存
No Power, Not Charging
My Macbook Air A1369 wont power on. My battery died already, so whenever I want to use it, I need the AC power connected. Then this morning when I tried using it, the magsafe indicator light wont turn on. tried using another 45W magsafe adaptor and still wont work. I used both magsafe adaptors on another Macbook Air and they both work. Does anyone know why my Macbook wont turn on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have similiar problem. But My macbook have strange issue from one day to a another. I have something like taht my battery is charging. My macbook sees battery is charged but after when i unplug magsafe power cord it just turn off like he dont have power. I ordered new i/o board cable for th eon switch. And i gonna see what gonna be. But I'm !#^&@@ because i need laptop for my work and now i cant use battery
完成的
添加一条评论
8个答案
已选择的解决方案
I would replaced the DC-In board first. There are five different units in the A1369 line, to get you to the correct part and installation guide we need the last three figures of your serial number: http://everymac.com/ultimate-mac-lookup/...
这个答案有帮助吗?
得分 3
7条评论:
Serial Number starts with C02F****DDR3
完成的
Apple MacBook Air "Core 2 Duo" 1.86 13" (Late '10) Specs
Identifiers: Late 2010 - MC503LL/A* - MacBookAir3,2 - A1369 - 2392
完成的
Here's how to replace the I/O board with DC-IN port, and a video on doing it: MacBook Air 13" 2010 年末款 I/O 板更换
完成的
It's Apple part #661-5792. iFixit does carry this part: http://www.ifixit.com/MacBook-Parts/MacB...
完成的
sir is there a way to test if it is just my I/O Board thats busted?
coz i wouldnt want to replace my I/O Board only to find out that there is more to replace.
Im better off buying a new mac air.
完成的
显示更多的2条评论
添加一条评论
you can do first is SMC reset by pressing and holding 4 buttons on the keyboard to reset all the system hardware . press and hold ( Left Shift+option+command+ power button ) for approx 5 seconds then put the charger inside then check its charging or not . if still not light in the charger remove the charger . hold the power button and put the charger in after pressing and holding power button after 10 sec release the power up button and press it again . your system will boot up may be . if boot up donot remove the charger . use it for a while and check its charging or not . if not then restart it from the mac osx . if still not power up then your have to open it up for checking whats wrong inside .
这个答案有帮助吗?
得分 1
2条评论:
tried it and the magsafe LED indicator still wont turn on, and unit still wont charge.
how can i tell if its the I/O board thats not working?
完成的
yes you have to change the I/O board to work as normal
完成的
添加一条评论
MacBook Air battery (inbuilt battery) dead plug to power adapter no light on the power adapter and I also did the SMC resset still yet no light on the power adapter
这个答案有帮助吗?
得分 1
1条评论:
I am having the same problem, did you find a solution for this?
完成的
添加一条评论
My macbook air is not turning ON and the charger light is also not turning ON.
Please suggest solution.
I had done all sort of SMC resets etc.,
这个答案有帮助吗?
得分 1
添加一条评论
I had same issue with my macbook air. No boot and no charging. SMC reset didn't work. Unpluging charger and heating with dryer didn't work either. The solution was to open it up, unplug the battery from main board, wait half an hour and I could boot macbook. I noticed that battery was already 40% charged when it started up again, so macbook not being able to start was not due to low battery. It was due to some kind of crash or soft malfunction which entirely prevented macbook from booting until battery was unplugged from motherboard.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same I removed the battery, waited 5 mins and plugged in the charger, came on orange light, plugged in battery was charging laptop worked without power adaptor in, but NO green light on chrger when plugged in but showed charging on screen. Initially green light came on but then changes to orange
这个答案有帮助吗?
得分 0
添加一条评论
Charge your laptop full, charger light should go green, then try to power on the laptop, it will work.
这个答案有帮助吗?
得分 0
添加一条评论
Clean where the plug goes! I had tried everything suggested,, this was only thing that worked.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kit Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 37
总计 76,851
