My rubber grip is coming away...
Is there a way to reseat / realign the rubber handgrip on a Xbox Elite Series 2 controller??
Hi Craig!
Thanks for the pictures! Unfortunately, this is a common issue…
Best thing to do, is to replace them! If you need a guide or part, please let me know!
这个答案有帮助吗?
Yes that would be great, thanks!
Replacement (only top) parts can be found on Microsoft: https://www.microsoft.com/en-us/d/replac...
Guide: Xbox Elite Wireless Controller Series 2 上外壳更换
For the bottom part, you can use this: https://www.microsoft.com/en-us/d/replac... (you might want to check Microsoft first, otherwise you can buy it on Amazon).
For the bottom part, you included the same link???
Sorry, posted the wrong link for the bottom part. Here it is: https://www.amazon.com/eXtremeRate-Repla...
Hi,
I'm Joe ... i have had the same issue and for me it's all about functionality
over looks. I just made a few cuts to remove loose rubber and then re-gripped
using tennis grip tape and a little double-sided tape to secure it seamlessly.
Feels good and works even if doesn't look like an award winner.
Sydney Aus
这个答案有帮助吗?
过去 24 小时: 18
过去 7 天: 74
过去 30 天: 351
总计 4,449
3条评论
Hi! Could you share some pictures with us regarding this? Thanks!
由 koppie007 完成的
Updated with photos
由 Craig Ireland 完成的
I have not found a glue that will hold it yet. I minimized it on one controller with a silicon cover that made it hard to see or feel.
由 Wesley Mason 完成的
