跳转到主内容
加入维修社区 - 创建账户
第四代 Sony PlayStation 5 DualSense 手柄(DualShock 系列的继任者)的维修指南、拆解和故障排除信息。通过型号 CFI-ZCT1W 和主板型号 BDM-040 识别。
How do I tear it down
I need to know how to test it down
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi!
I think the most easiest way is to follow this guide: DualSense手柄第二代主板更换
This basically tells you how to get to the last part. I know this is for the V2 controller instead for the V4, but the process is almost the same.
这个答案有帮助吗?
得分 5
4条评论:
what is the diffrence bertween the v2 and the v4 coontroller?
完成的
Hi!
Minor differences. Just some other parts are used from another brand. Like the triggers and rubbers are slightly improved. No big changes.
完成的
Thats wrong. The whole motor/shoulder trigger assembly is different. There are no screws on the front side (where the buttons press against the board) and no metal axle for L2/R2 also the flex-connectors are just 3 pins
完成的
Hi! I'm sorry! You are correct! The difference between the V1 and V2 aren't that big. Later on they did start with the 3 pins! My appologies!
完成的
添加一条评论
V4 has 4 wires instead of 2. also the flex cables are smaller.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Tavin Bauerle 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 78
过去 30 天: 386
总计 7,455
