跳转到主内容
加入维修社区 - 创建账户
第三代起亚 Kia Rio 于 2011 年 3 月 1 日在日内瓦车展上首次亮相,依然基于现代 Hyundai Accent 打造。
Engine misfire and jerking
I’m having a issue with my 2015 Kia Rio 1.4L (GCC specs). Sometimes when I start the car, the ignition takes longer than usual, and when it finally starts, I hear this jerking sound from the engine if I shift into D or R. The RPM stays at zero, even if I try to accelerate or drive. I changed the spark plugs yesterday, but the problem’s still there. The engine even shuts off sometimes while I’m on the road. https://drive.google.com/file/d/1ub3aeZB...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
My car sputters and coughs
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
You'll first want to get the car scanned or buy a code scanner for yourself like this. That said, I know from experience with these older Kias that predate the faulty Georgia factory engines CAN be better then the newer engines (but are prone to oil consumption). In the meantime, see if you can siphon some gas from the tank and make sure you do not have bad gas using a kit like this kit.
Look for a misfire code, and start there; that's what it was for me when I had to look at a Forte from this period with the 2L i4. The component that caused problems in the one I looked at was the ignition coil, but I would start by replacing all four spark plugs if you see misfire codes, as it's a cheaper repair than the ignition coils. Make sure you clear the code so it stays out of the OBD2 code history. Once you swap the spark plugs with the same issue, move one of the ignition coils to another cylinder to see if the code moves; if it does, you know it's the ignition coil.
If changing the isolated ignition coil does not help, you may want to change the remaining coils, as the others may be on their way out, and check to make sure the injectors are good. If the injectors are fine (or you decide to try before condemning the car) and EVERYTHING ELSE (including the coils) has been checked over, you may have a more serious issue, like a bad engine. That said, before condemning the engine/car (assuming you have done everything else, mainly gas check/spark plugs/fuel injectors/coils), do two things:
This is what the page should look like (Note this is an EXAMPLE; find the SM for your Rio and locate the info specific to yours):
That said, here's the specific data for yours.
  • Get a borescope camera like this and check for issues like scoring in the piston rings, and severe oil consumption.
这个答案有帮助吗?
得分 3
4条评论:
Hi Thanks for you Reply After this happened i've changed the Spark plugs, then it's started to engine stop in the middle of the road, and coils also bit weak do you think it could be the any mechanical issue since the rpm in zero ?Hi, thank you for your reply. After this issue occurred, I changed the spark plugs, but the engine started stalling in the middle of the road. The coils also seem to be a bit weak. Do you think there could be any mechanical issues since the RPM is at zero?
由完成的 分享
and i forgot to mention there's no engine check light or anything showing in the dashboard
由完成的 分享
@shaheer90269 I would try to replace the weak coils and have all 4 handy just in case especially if the gas isn’t bad. That said though most of the time it’s usually cheaper to try new injectors but as long as it ran fine prior they may be fine. When the Kia I mentioned had issues I did the plugs, then the injectors and neither helped, it was the coil (last thing I suspected given that one had Denso coils). However the injectors tend to be a heck of a lot cheaper.
由完成的 分享
I've scanned the car and found codes P0335 and P0620. The crankshaft sensor was the issue, so I replaced it with a used one. So far, there have been no problems. Thanks for your reply; I've learned a lot from you. @nick
由完成的 分享
添加一条评论
添加你的答案
Shaheer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 98
总计 3,450
